95 that suddenly won't turn over starter.
Old 08-11-2012 | 03:16 PM
Triggerhorse's Avatar
Question 95 that suddenly won't turn over starter.
Hello everyone. I am in a bind.I tried to start my 95 Limited sedan up and all I got were dash lights(no sound at starter). After many tests ie: Starter, battery, vats system (all check out fine) I pray I am not stuck with: The dreaded Tow to a GM dealer. I should add that I jacked her up and tested the starter at the solenoid. The car started and ran for about a couple seconds then shut off like someone turned the key off. I did this about 4 times more but everytime it started and ran 2-3 seconds then shut off-- even when I had someone pump the accelerator after the engine started but it still instantly shut off.
No pass key light illuminating -ever! Any ideas like-- What would you do??
Old 08-11-2012 | 05:30 PM
You should have a second key to use . Try it ! Key could have lost some info.
Old 08-11-2012 | 08:22 PM
Unhappy re
I have done that and the vat security checks out.
Old 08-12-2012 | 09:58 PM
Default Finished?
I worked for 2 hours today trying to figure this out-- Failure!!
Old 08-13-2012 | 06:14 PM
There have bee some reported problems with the ign switch assys. Might want to confirm it is completing the circuit to the rest of the vehicle.
Old 08-19-2012 | 01:52 PM
Default Cannot solve but must be electrical
After 2 years--Suddenly my power trunk open switch works-- coincidence?
Old 08-19-2012 | 05:33 PM
IMO I don't believe they are related.
Old 08-20-2012 | 11:12 PM
Unhappy Solenoid??
How about this? Maybe the solenoid needs to send a message back to the ignition that the circuit to the starter is still in place or the security system shuts the fuel off. Remember that the cuicuit is complete until I pull the screwdriver jump back off when it started underneath it.
  #9
Old 08-21-2012 | 03:07 AM
The vat system typically blocks power to the starter solenoid and fuel injectors. Sounds like it is doing that when it should not.
  #10
Old 08-22-2012 | 12:56 AM
Question Newrockies Pro ByPass module
I believe I may be a good candidate. Any feedback would be greatly appreciated.
