Changing fuel pump 1996 riviera
Old 01-03-2012 | 12:22 AM
Trukindave's Avatar
Default Changing fuel pump 1996 riviera
I have a accss panel in the trunk to repace the fuel tank. I was wondering do I still need to drain the tank or is that if you just have to drop the tank?
to remove some of the weight
I decided to replace the fuel pump as seen in my other thread
Old 01-03-2012 | 10:01 PM
Trukindave's Avatar
Here is everything I have done so far, I am hoping that this help. I am not sure where to go from here.
I removed the wiring harness from the fuel pump and I replaced the fuse and turned the key and it popped a new fuse
I removed the ( ICM ) Ignition control module And I replaced it with a new fuse and turned the key and it also popped a new fuse
I removed the fuel pump relay from under the back seat I replaced the fuse and turned the key and IT did not pop the fuse. So does that mean the short is between the wiring harnes and the pump relay?
I am hoping I am making progress
Old 01-04-2012 | 01:28 PM
Trukindave's Avatar
Problem solved: It ended up being the fuel pump relay: Thanks all..
Old 01-04-2012 | 07:04 PM
Its good to hear you got it fixed. Sometimes its the smallest things that cause you problems.
Trukindave
10-05-2012 12:52 PM
WRANGLER
05-05-2012 10:25 AM
cvcmab
10-24-2006 10:01 PM
scarecrow1941
12-08-2005 04:19 PM
scarecrow1941
10-06-2005 10:37 PM
