Manual control, no high speed on blower motor.
I have a manual control heater AC control and I had no blower. Checked at the fan and had power so I replaced the blower motor and that gave me the blower again except for high speed.
I always thought that the high speed was a direct feed to the blower motor and bypassed the blower motor resistor. Is there a chance that there is a relay in the high speed circuit ??
Would this indicate that the switch is likely bad ??
Where is the blower motor resistor located ??
Running across different answers. This diagram is correct and the third relay from the left, labeled blower relay is the five pin that's bad on mine. I swapped a couple of the relays (All the others four pin) around and this one gets the blower spinning but good
Not sure what the fifth wire is for but there is a wire in the connector for it so 5 pin it is.
Buick Forum Editor
06-09-2014 03:41 PM
Buick Forum Editor
06-06-2014 11:28 AM
