Ignition spark testing
Old 03-05-2007 | 04:41 PM
bassasasin's Avatar
Have you ever wanted to
really check ignition spark?
Checking spark with a normal spark plug does not check the coil ignition spark
system effectively.
Coils can fail internally under higher stress and loads.
It is better to make a test plug and widen the plug gap to 1/4 to 3/8".
Put a good ground on the threads and use it on each cylinder testing for jump on wires also. This increases
stress loads on the coil and wires and provides confidence in performance.
Keep em' wheelin'</span>
Huneycutt
02-06-2009 10:16 AM
cllm
11-22-2006 03:41 PM
haubest
09-25-2006 07:23 PM
Twi_prime
07-09-2006 01:43 PM
dwallbaum
05-03-2006 04:08 PM
