Another Climate Control Problem
Re: '95 Bu LeSabre. 4dr Limited w/climate control. I just found a solution to the problem of not getting any air coming out of the dash vents with the expert help of Hanky. The problem that I have now has to do with hot air coming out of the driver's side vents but cold out of the passenger's side. As it turns out, I can manipulate that by moving the linkage/lever on top of the heater/ac housing.( of course after getting the glove box out of the way) Something that controls the action of that door has gone awry. Where can I look what can I do and where? Thanks. Zuko
Hi Hanky.
Come to think of it, that little square vacuum manifold with all of those tubes connected to it does have one male port that doesn't have anything connected to it. I just thought it was one that just wasn't being used. When I first saw it, I looked around for a tube that might have come off, but I couldn't find any. Other than that, if that's not the one, would the tube that might be off be inside the box or outside. Bob
