1997 Lesabre rear window defroster
Hello,
I have a 97 Lesabre in which the rear window defroster quit working. The light on the switch comes on, power to both sides of the fuse. I see no nicks or rubs anywhere in the grid, although, none of the defroster works at all. Any ideas or advice? Thanks in advance
The next step is to use a voltmeter and see if there is any voltage being sent to the defroster grid itself.
Did you have a symptom of static in the AM radio when the antenna was working the last times?
Test if you have power to that box, if your car has one there. Test to be sure the other side of the fog grid is grounded.
mike83
01-04-2010 01:53 PM
