Grand National The Rear Wheel Drive Turbocharged Coupe that has remained a legend for decades
Buick GNX will not start.
Old 04-01-2018, 06:46 PM
Default Buick GNX will not start.
Hi Chris, received your note but not confident my message even went out. I'd check distributor, may be reinstalled 180 degrees off if tab and slot or if geared can be off also. Usually set by #1 piston at TDC for starters if really off. Yes I've done it also lol. Hope this helps......
Regards, Rich
PS too- Pretty sure those would still have the tail end of distributors (no points), my '87 Corvette did.
Old 04-02-2018, 03:34 AM
Messages seem to be sending OK, so much for distributors. Buick seems in general to be further advanced and well built, lasting longer as I am slowly learning about.
This is of interest: https://en.m.wikipedia.org/wiki/Ignition_system. Loved the dual point distributor, those worked great. Had an Accel mechanical advance and Ford vac/mech advance, both worked perfect in my Plymouth ('69 road runner). Would run Ford vac advance mostly for street. With the Accel mechanical only advance, was like running a second carburetor.
Did get away from all that after many years, finally lol. https://en.m.wikipedia.org/wiki/Cran...osition_sensor Maybe? https://itstillruns.com/differences-...r-7467710.html
Buick Forum Editor
07-19-2017 06:56 PM
Buick Forum Editor
10-15-2014 07:47 PM
Buick Forum Editor
11-26-2012 05:44 PM
aimee
01-18-2009 11:29 AM
Troys 69 GS 400
Grand National
06-10-2007 11:03 AM
Quick Reply: Buick GNX will not start.
