Shuttering when increasing speed.
Old 02-23-2010 | 01:59 PM
bob55's Avatar
Chances are a bad spark plug or wire. Make sure the wire end isnt rusted at the coil or plug. Check you wires with an ohm meter. Usually 1 ohm per foot is the rule of thumb.
  #12
Old 05-25-2010 | 12:43 PM
mnewbolds's Avatar
I am having the similair problem as the Original post. But I KNOW it isn't motor related. The motor has less than 15k on it and just chenged all of the ignition components. Also checked the timing and compression. Tip Top. As well as all new tires, brakes, tie rods, ball joints, and had an alignment done. Still wobbling at 45-55 and I noticed that it vibrates when the suspension compresses.
  #13
Old 06-17-2010 | 02:19 AM
james1's Avatar
It sounds like you are not exposing right, are you checking your meter to make sure you are properly exposed... maybe you need a light meter to tell what to set your camera on.
  #14
Old 06-28-2010 | 03:41 AM
jank8431's Avatar
If you put your camera on shutter priority, it will automatically compensate by having your lens open wider (aperture). If you are doing it manually, then you have to adjust your lens opening wider (smaller number like from 8 to 5.6 or wider). However, you will lose your depth of field (background will get blurry). You can use your camera's flash to stop fast action, also.
deraildoug
06-02-2007 01:01 PM
audioantny
05-16-2007 12:21 AM
audioantny
05-12-2007 03:10 AM
audioantny
05-12-2007 02:57 AM
mybuick
04-04-2006 11:58 PM
