N bdy skylark tail/turn sig. possible solutions
This might work on the skylark tail light/turn signal kerfuffel..Be sure to clean both circuit bulb boards of old di-electric grease/rust/spooge.Clean the bulbs where they plug into the boards too.Electronics cleaner is good,I used windex,let 'em air dry.Then use Dioxit on all contacts,I like the one with the little needle applicator.Go easy on the di-electric grease,as a little goes a long way.Don't put the circuit boards back into the header panel untill after you test.That's how I found out I had a bulb in upside down.Oh,my 'lark has the lighting group option,and has the convenience
center,not the typical flasher/turn signal relay(s).The Hays manual says it's "proably located under the dash,in the vicinity of the steering column"
Ok then! Like near the console,or the glove box?
For much hilarity,check my newbie weighing in,in the new member section,on fun with multi switch replacement.
replacement
replacement
racing.nut
01-30-2012 12:15 AM
69Rivi
04-19-2008 11:42 PM
