Drive Belt Tensioner Pulley 1997 LeSabre
Hi, from the sound of it the bearing has sized up and the pulley is loose. Please tell what your "easy fix" was. Surprized that the belt has not torn up. Same happened to mine (97 LaSabre). Had to replace the tensioner assembly. see previous posts from 8-1-07 and 8-9-07.
The easy fix was that I didn''t have to replace the whole tensioner assembly, just the pulley itself. One bolt in the middle and correctly re-routing the belt. I told my mechanic and he said the bearing did indeed let go. Running good and strong now.
awbooth
06-15-2013 11:26 PM
h.fork
09-21-2006 03:35 AM
