Buick Keyless Entry Remotes & Programming
Old 10-09-2005 | 08:53 PM
93Miata's Avatar
What does your local dealer charge forBuick keyless entry remotes?
MyBuick dealer wants $119 a piece plus $35 for programming for each of my cars (97 Lesabre, 95 Park Avenue).
I'm curious to see what other dealerships are charging for new remotes and programming.
I'm done with ebay because the listings show new remotes, and 3 out of 3 times I've won - I end up with junk that doesn't work and won't program. First one was superglued together and cracked. Can't check the battery if you can't even open it. Second one was completely corroded inside from water and didn't work. The 3rd one only 1 button worked and it looked like someone tried to superglue the circuit board pieces back together. Each one was advertised as new, or like new and they obviously weren't anywhere close to that. The Keyles Ride site is run by one of those same lying ebay sellers, so thats off the list too.
What does your local dealership charge? I bet there's some that want even more than what mine is charging.
Old 10-12-2005 | 02:06 PM
Patrick's Avatar
Administrator
i used to work at a dealership (not buick) and they charged 70 bucks a piece to program a remote.
Old 11-05-2005 | 10:44 PM
firefighter0029's Avatar
What kind of remotes are they the round ones or the suare ones? I can probably tell you how to program them.
Old 05-27-2006 | 02:02 PM
BlackLuve's Avatar
I'm not sure if this site will help you but I was able to find a new one for mine *have not purchased it yet*.
www.thepartsyouneed.com
Buying a transmitter on Ebay doesn't sound like a good idea. The ones I looked at seemed like they had literally been "put" back together. Good Luck!
Old 06-27-2006 | 02:15 AM
Toadster25's Avatar
You just have to jump the diagnostic connector under the dash on your 97 Lesabre terminal 4 to 8 with the key on. After you jump them the locks will cycle once and then you have to hold the lock and unlock buttons down at the same time for about 15 seconds till the locks cycle again.
Old 07-06-2009 | 04:12 AM
mucha's Avatar
Hi
Most remotes can be programmed manually; however some must be programmed by a dealer or automotive locksmith in your area.
Please email us with your VIN# and also just in case the year, make and model of your vehicle (it is easy to make a mistake in the VIN #)
Base on this information we will determine for you if you can program the remote yourself.
We offer a wide selection of original manufacturer keyless entry remotes (RKE, fobs) at discount prices. In most cases you can also program the remote yourself with our easy to follow programming instructions. Please visit our website at
http://www.carandtruckremotes.com/
If you have any questions or have any specific inquiries about your remote system please contact us at customercare@carandtruckremotes.com including year, make and model of your vehicle.
You can also view our FAQ page for answers to common questions. Link below
http://www.carandtruckremotes.com/faq.html
Best Regards
Customer Care
http://www.newkeylessremotes.com
http://www.keylessentrystore.com
Old 08-08-2017 | 10:19 AM
WyrTwister's Avatar
Is this the OBDII connector ?
Need to program a 2006 Lacrosse .
Thanks , :-0
Wyr
God bless
dwenrhod
03-24-2015 08:21 AM
MatrixEVO
09-19-2013 02:34 AM
jrasche2003
07-06-2009 04:18 AM
Hal H
07-06-2009 04:16 AM
timmyj
02-24-2007 09:26 PM
