95 Lesabre fuel pump relay
Old 07-13-2008 | 11:49 AM
cvball's Avatar
Trying to determine which relay under hood belongs to fuel pump,no stickers and manuals i have dont show relays..any help greatly appreciated..and believe relay may be getting bad so want to swap with one of the other ones..so if other relay ids are known that will help also.
Old 07-13-2008 | 06:10 PM
samueljackson's Avatar
it is not under the hood. you have to renove the lower kick panel with a torx bit (T15). it is the relay 2nd from the top, on the right side, or more towards the pass. door.
Old 04-25-2011 | 02:31 PM
the colonel's Avatar
You can open the glove box and move the rubber stops out of the way and drop glove box door down and look inside to the right for the relays
snik
06-16-2012 07:42 PM
95riviera
04-03-2008 06:40 AM
cvcmab
10-24-2006 10:01 PM
scarecrow1941
12-08-2005 04:19 PM
scarecrow1941
10-06-2005 10:37 PM
