92 Skylark shuts off
#67
its running pretty good now, just my RPM's like to drop while im accelerating but i still got power, and if i try to acclerate more it'll just stay at 2k rpm's, but if i let go of the gas then push back it'll work again =/ lolz hey would you know how much a ignition would cost? the slot where i put the key to start it.
#68
Your little rpm problem could be fuel or air. You can check over everything in the intake just to make sure everything is clean and clear. If you have access to a fuel pressure gauge, you can try checking the pressure with the key on, engine off, and again with the key on, engine running.
I'm not sure how much the ignition costs, sorry.
#69
