2000 Cruise won't stay on Help
Old 09-10-2012 | 11:26 AM
jvm's Avatar
jvm
Default 2000 Cruise won't stay on Help
My mom's 2000 cruise won't stay on. It will work if I keep the cruise button pressed down on the steering wheel.
It will quit if I let it up.
Anyone Know what to look at? Thanks
Oh it only has 13K on it!!!!!!! She son't get out much
Old 09-10-2012 | 03:50 PM
Most of the time a relay is used to activate the cruise control. If you have the owner's manual check in the relay section and it will tell you which relay and where it is located.
Sometimes if the stoplite switch is in need of adjustment it will cancel out the cruise control.
Old 09-16-2012 | 04:26 AM
Merc6's Avatar
What speeds are we using it at?
Old 09-17-2012 | 10:55 AM
jvm's Avatar
jvm
We were on the freeway doing 70MPH Thanks
Old 09-27-2012 | 11:31 AM
jvm's Avatar
jvm
When I keep the switch pressed down it works, When I let up the cruse dies. Fustrating
Old 09-27-2012 | 12:29 PM
From all the descriptions you have provided, it sounds like there is a problem with the cruise on/off switch itself. If there was a bad connection or relay problem somewhere the control would not stay working when you keep the button depressed.
indo
10-29-2012 08:23 PM
1990buickcentry
06-28-2010 05:48 PM
Cassious6
11-22-2008 06:48 PM
stone
05-25-2006 01:59 AM
