How To Replace the MAF Sensor on a '02 Park Avenue
Old 10-20-2011 | 12:47 PM
BuickBag's Avatar
Default How To Replace the MAF Sensor on a '02 Park Avenue
Hello ladies and gents,
The following is the proper procedure for replacing the Mass Air Flow Sensor (or MAF Sensor) on a '02 Park Avenue Enjoy!
  1. Turn OFF the ignition.
  2. Remove the fuel injection sight shield.
  3. Disconnect the mass air flow (MAF) sensor electrical connector from the MAF sensor.
  4. Remove the screws that hold the MAF sensor to the throttle body.
  5. Remove the MAF sensor from the throttle body.
-Installation-
  1. Install the MAF sensor to the throttle body.
  2. Install the screws that hold the MAF sensor to the throttle body. Tighten the screws to 27 inch lbs. (3 Nm).
  3. Connect the MAF sensor electrical connector to the MAF sensor.
  4. Install the fuel injection sight shield.
wmorrisw
08-21-2012 07:59 PM
wizzard1222
07-24-2012 02:15 PM
BuickBag
08-30-2011 12:41 PM
roughcreek
10-27-2008 02:54 PM
lefty2053
09-24-2007 07:09 PM
