2000 Buick Century bad motor mounts
Old 12-14-2011 | 10:28 AM
greendurango's Avatar
Default 2000 Buick Century bad motor mounts
I have a 2000 Buick Century that has the 3.1 3100 engine, I thought I was having tranny problems with the car but my mounts had a lot of play in them, what would happen is when you take off from a stop you would feel like a slip/jerk all gears shifted and changed correctly, it did not do it all the time as well, I replaced the dog bones mounts and the top rad support mounts, and the tranny mount on driver side, and I have not felt it as bad, I cannot figure how to change the motor mount on pass side, the mount is liquid filled! I have never seen that before is that pretty commom? thanks a bunch!
Old 12-21-2011 | 09:31 PM
anyone? please help!
Old 12-21-2011 | 09:35 PM
I can't say I've noticed mine. I haven't had that problem *knock on wood* but i'll check tomorrow if the weather cooperates to see if I have any ideas.
Old 12-22-2011 | 09:16 PM
Thanks Bud, I got a Hayes Manual but it aint much help, it did not list the proceedure for changing out the Pass side motor mount that mounts under harmonic balancer in the frame, does anyone Have a factory service manual that shows how to do it? thank you!
Old 12-22-2011 | 11:36 PM
Merc6's Avatar
Believe it involved(jack stands under rearward control arm) a piece of wood under the oil pan with one jack lifting after you undo the top passenger motor mount.
I have the W body Century Haynes 19010 what page did you look @
Page 2A-15 to 2A-16 for pics of the bolts. I can search for another How-To in a few mins.
They make non hydro ones. I can't 100% say they are the same as the 3400, 3500, and 3800. When the time comes I will go to the solid one and poly the uppers.
http://www.autozone.com/autozone/par..._195311_16129_
Old 12-23-2011 | 10:40 AM
Yea, I think thats the same manual I have I might have a earlier one I dunno? I searched around and I cannot find the solid one the only ones the only one I can find is the Anchor 2796 http://www.rockauto.com/catalog/rafr...28-2796-111412
if you know where I can find the solid one please let me know I have checked all the parts stores, advance, autozone, oreilly, napa
Old 12-25-2011 | 03:04 AM
Merc6's Avatar
Were you able to find that part in the link above your post?
This is another one. Others confirmed it to be 60 and 90 degree V6 universal.
http://shop.zzperformance.com/store/...ine-Mount.aspx
The upper ones can be redone with these. These should be universal between 60 and 90 degree just debating if I want to go hardcore(red)
http://shop.zzperformance.com/store/...or-Mounts.aspx
Old 12-27-2011 | 10:05 PM
thanks for the link, it was lots of help! is the factory mount a liquid filled mount?
  #9
Old 12-28-2011 | 12:39 PM
Merc6's Avatar
Yes it's filled. When they go, it's messy.
Majesty
11-13-2014 10:03 AM
schultz51
04-16-2009 09:19 PM
splice01
12-17-2008 03:55 AM
grnmnstr
02-06-2008 11:02 PM
Noel5560
01-07-2006 09:24 PM
